tmay
#1 Posted : Tuesday, March 3, 2009 2:21:05 PM(UTC)
tmay
I'm using ISO dimensioning, and I'm having difficulty dimensioning the bottom view (either the view off of the side or that off of the end).
I want to use the same origin as the model for all view dimensioning but dimension text and leader are incorrecty created in either the x or the y dimensions, dependent upon which of the bottom views I am using.
It looks like a dimensioning limitation that needs to be addressed, but if there is a workaround (flattening the view possibly) I will try that.
thanks
tom
tmay
#2 Posted : Tuesday, March 3, 2009 5:15:15 PM(UTC)
tmay
I decided that the easiest solution was to create a new copy of the model, and orient the bottom of that model as the top view.
Works fine.
tom
