SG2009
#1 Posted : Wednesday, January 26, 2011 11:00:52 AM(UTC)
SG2009
I need to model a gear.
Can anyone provide me with a conceptual plan for modeling one?
I could muddle my way through but I suspect that someone with experience would know lots of short cuts.
L. Banasky
#2 Posted : Wednesday, January 26, 2011 3:04:29 PM(UTC)
L. Banasky
I don't know what types of gears you are looking for, but a good place to start is here:
http://www.3dcontentcentral.com/Default.aspx
or some gear manufacturers have models available on their web sites.
billbedford
#3 Posted : Thursday, January 27, 2011 3:23:15 AM(UTC)
billbedford
I found this was the easy way to draw gears [URL="http://www.thingiverse.com/download:10581"]http://www.thingiverse.com/download:10581[/URL]
you will need to also download Openscad [URL="http://www.openscad.org/"]http://www.openscad.org/[/URL]
posh.de
#4 Posted : Thursday, January 27, 2011 5:57:11 AM(UTC)
posh.de
Tup48
#5 Posted : Thursday, January 27, 2011 11:18:21 AM(UTC)
Tup48
If you would like to draw your own gears you my want to look at this site. http://www.cartertools.com/involute.html
Attached are two 24- Pitch Gears that I did using this method. If you have a spread sheet like (Microsoft Excel) you could setup a spread sheet so all you would need to enter would be the Number of Teeth, Diametral Pitch and the COS for the Pressure Angle. 0.968148 for 14-1/2 and 0.939693 For 20
Richard
2-24 Pitch Gears.vcp (1,258kb) downloaded 6 time(s).
SG2009
#6 Posted : Thursday, January 27, 2011 1:47:49 PM(UTC)
SG2009
Thanks for all the great ideas. Between them there are a few good ways of drawing gears.
I actually took a stab at it as well, using a straight line instead of an involute for the gear shape. I will take a look at modeling the involute.
Here is my simple way of modeling a gear.
Draw concentric circles for the root diamter and the outside diameter.
Draw a midpoint line centered with Y equal to half the tooth thickness and X equal to sqrt(ptich diameter^2-Y^2) with angle minus the pressure angle with length long enough so that it intersects both circles.
Draw another midpoint line with Y=-Y and the angle positive the pressure angle.
Select the circles. Use trim tool to trim lines to circles.
Select the lines. Use trim tool to trim the outer circle.
Select the lower gear edge and the gear edge that was part of the outer circle.
Use the polar duplicate tool to copy the select edges at angle 360/(number of teeth).
Use the fillet tool to fillet the edge intersections starting at the top. The inner circle will disappear where it is not needed when the fillets are added.
Delete the bottom tooth edge and the second tooth edge at the outer circle.
Select all the tooth edges.
Use the polar duplicate to make the number of teeth with a rotation angle of 360 degrees total.
Select the outline and group it.
Extrude the outline into a gear.
I'll have to work on doing the involute, but the above process is pretty quick to do.
Thanks. I will have to look at all the gear design programs suggested. For now all I need is a pretty picture.
