Steve.M
#1 Posted : Monday, June 1, 2009 10:26:05 PM(UTC)
Steve.M
Tim,
At one time (certainly in build 788, I have just re-checked) it was possible to extend a line to a surface boundary, attempting this now causes an error popup.
Note: It also (on pc build 835) after the error, causes the dynamic rotate (middle mouse button) to change to dynamic zoom.
Attached:
pic01 showing simple example (example file attached)
Pic02 show error, although the line is extended beyond the boundary.
- Steve
extend to surface.vcp (10kb) downloaded 5 time(s).
Steve.M
#2 Posted : Tuesday, June 2, 2009 1:05:07 PM(UTC)
Steve.M
Hi Tim,
The trim to surface is also now giving errors, which does work in build 788. I hope this is just a bug and not a removed feature?
- Steve
#3 Posted : Tuesday, June 2, 2009 7:03:34 PM(UTC)
Steve,
Repeated, found and fixed in 836.
Steve.M
#4 Posted : Wednesday, June 3, 2009 4:55:51 AM(UTC)
Steve.M
Tim,
Thank you,
- Steve
#5 Posted : Wednesday, June 3, 2009 12:55:17 PM(UTC)
I haven't tried the method you used. But, i get the dynamic zoom "bug" and i don't know why nor what triggers it. I usually dont' find out until 4 or 5 steps beyond, when i'm banging my head on the desk over non-response to dynamic (middle mouse button) panning. Hitting the back-tick key doesn't release the mode into select. So, i think i sometimes am not even getting selections, or if i do, i still don't fall into a mode permitting dynamic panning.
I thought maybe VirtualBox had something to do with it, but in all respects i can recall, VBox has not caused my other apps to behave oddly or in quirky ways. I think VBox is not tripping VCAD up. I don't think my system resources are the problem. It's probably some code snag that's random, or based on some irreproducable (due to my memory span) chain of steps...
ttrw
#6 Posted : Wednesday, June 3, 2009 2:23:38 PM(UTC)
ttrw
I'm hearin' yer Bro! :D:D
Steve.M
#7 Posted : Wednesday, June 3, 2009 3:04:51 PM(UTC)
Steve.M
No, it is the same on my setup. I did make note in my first post pointing out the problem.
- Steve
