Steve.M
#1 Posted : Wednesday, May 20, 2009 11:01:39 AM(UTC)
Steve.M
Did not know which section to post this one.
If there is a cone solid, or cone create via solid/surface revolve, or even a cone created using a chamfer, then the end point of the cone cannot be snapped to, it is not seen as an endpoint.
Is this by design?
- Steve
#2 Posted : Saturday, May 30, 2009 4:50:05 PM(UTC)
>>If there is a cone solid, or cone create via solid/surface revolve, or even a >>cone created using a chamfer, then the end point of the cone cannot be >>snapped to, it is not seen as an endpoint.
>>Is this by design?
I'm currently only grabbing snap points on geometry with length. Will need to investigate grabbing stand alone vertices.
#3 Posted : Saturday, May 30, 2009 4:50:59 PM(UTC)
>>Is this by design?
I'm currently only grabbing snap points on geometry with length. Will need to investigate grabbing stand alone vertices as that is also a relative point to snap to.
Steve.M
#4 Posted : Wednesday, July 22, 2009 11:52:10 AM(UTC)
Steve.M
I nearly forgot to thank you for adding this snapping.
Regards,
- Steve
Steve.M
#5 Posted : Thursday, July 23, 2009 2:22:59 PM(UTC)
Steve.M
Tim,
It appears that only the "Cone 2 points" can be snapped to at its endpoint. There is no endpoint snapping on the other cone types (or for created cones from chamfers etc).
- Steve
#6 Posted : Wednesday, July 29, 2009 8:08:01 PM(UTC)
Originally Posted by: Steve.M Go to Quoted Post
Tim,
- Steve
Hi Steve,
In addition to curves, we also snap to points used by the designer to define the shape. So the Cone 3 Points is snapping to the second point used to define the cone.
