2D Drafting
Modify Slope~ Reverse (#1317)
Hello, 2d/3d V6 (build)787 (PC) When using control point splines, I can use "Modify slope"~ "Reference" for a slope which then usually goes the wrong way, but when using control point splines the "Reverse" will not reverse the curve direction made by the Reference. - Steve
I thought changing the "object type" of spline may help, but instead the program simply crashed.
I really don't know how many times through the years I've stated that 'reference' slopes go the wrong way by default Thanks for bringing up again Perhaps if other people can verify this issue - we can finally get this changed !!
Steve.M wrote: I thought changing the "object type" of spline may help, but instead the program simply crashed.
Steve,
Any more info on how to repeat? Do you still have the file? If so email and I will see if its fixable for tonights upload.
Hi Tim,
Tim Olson wrote: Any more info on how to repeat?
I was not expecting(or looking for) a crash, so did not keep notes of steps etc as I was just drawing many different types of spline to check the "Modify slope" tool.
I cannot repeat the crash at this time, but will keep better track in case it happens again.
- Steve
Steve.M wrote: Hello, 2d/3d V6 (build)787 (PC) ...using control point splines the "Reverse" will not reverse the curve direction made by the Reference. - Steve
Steve
Fixed in 788.
Hi Tim,
Tim Olson wrote: Steve Fixed in 788. Tim
Thank you,
By the way, the problem appears in shark FX(pc) demo
Regards,
_ steve
so will 'reference' ing a spline into a surface or solid now no longer require reversing every time ?
jol wrote: so will 'reference' ing a spline into a surface or solid now no longer require reversing every time ?
Not yet, this just adds the ability to reverse the start/end slope of a control point spline. The extra flipping is based on which side of the surface you reference which I have not addressed yet.
Hi Tim,
This is still not working on the control point splines (788).
- Steve
Steve.M wrote: Hi Tim, This is still not working on the control point splines (788). - Steve
Steve
Can you send me an example?
Tim Olson wrote: Steve Can you send me an example? Tim
Hi Tim,
e-mail sent with simple example.
- Steve
Hello, I did find that is was own fault on this one. I was expecting to select the control point spline near the end to change its direction, when in fact I need to select the actual control point. I e-mailed Tim with the explanation of my error. - Steve
2D Drafting
