2D Drafting
Adjusting spline control points (#1280)
Todd Quinlan wrote: To get instant feedback as you draw, Click a start point and let go of the mouse then move to your next point and click again and repeat, the line will draw from point to point as you go.
Err....really?? When was the last time you tried using this tool?? You get no feedback whatsoever using this in the latest beta, with the method you describe.
edit- lets put it this way, this tool doesn't behave the way you expect it to. It does draw a spline, but only when you have deselected your path. What good is that?
ttrw wrote: this tool doesn't behave the way you expect it to. It does draw a spline, but only when you have deselected your path. What good is that?
I agree.
I would expect spline to work similar to the 3 point arc, whereas on the 3 point arc the last point does give realtime feeback and shows the curve change as you move the mouse pointer before you actually click that point.
Have to agree here .. spline tools are not nice in Shark
and you need nice splines to make nice surfaces
We need feedback, lines with a thickness, point graphics (not just 4 pixels stuck together) and anti-aliasing
See Pages .. or SolidWorks
(26kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
pages on-screen toolhints are also excellent !
Steve.M wrote: Not quite. When drawing (for example) a control point spline, you have to draw the first 3 points before the curve is drawn, you then move the cursor but there is no actual feedback in the change that will be made to the actual curve, not until you actually click the next point. For realtime feedback I would expect the curve to follow the cursor point, so it gives you feedback of the curve before you commit to the point being made, not given a result after the point is place.
I totally agree, this should be visible when sketching the curve so that the user can see what they are doing....which helps I find :D
I would like to see this at least on interpolate spline if not both spline tools, also can we have the option for 'edit points' OR 'control points' on an interp spline...currently only 'edit points' is shown (until trimmed)
BIG thx
jol wrote: pages on-screen toolhints are also excellent !
Apple Pages/ iWork.... What an app! I've completely dumped Word now :D (sorry for the OT).
But yes, the ease of use in that Pages spline tool- it's just how it should work imo, especially as Shark excels at spline surfacing :D
Thanks: 231 times Was thanked: 184 time(s) in 111 post(s)
ttrw wrote: Pages spline tool- it's just how it should work ..
I totally agree !
JL
oOo .. he's back !! Ni Hau !
2D Drafting
