rtaylor
#1 Posted : Wednesday, April 17, 2013 11:30:22 AM(UTC)
rtaylor
Can I install 2D 3D V8 on a PC running Windows 8? When I go to register there is not a listing for 8????
posh.de
#2 Posted : Thursday, April 18, 2013 8:21:12 AM(UTC)
posh.de
MS has unfortunately removed the configuration ("right-click > Properties > Compatibility") for disabling the [URL="http://en.wikipedia.org/wiki/Desktop_Window_Manager"]Desktop Window Manager[/URL] (which was introduced with Vista for generating the Aero eyecandy), i.e. the DWM is always running and even cannot be disabled by the application itself:
UserPostedImage
Therefore applications which do use [URL="http://en.wikipedia.org/wiki/OpenGL"]OpenGL[/URL] for the (accelerated) 3D display output as well as the Windows [URL="http://en.wikipedia.org/wiki/Graphics_Device_Interface"]GDI[/URL] for the 2D stuff (as e.g. dialogs and windows etc.) may suffer in a flickering or incorrect display output.
hth,
Norbert
BPL-RFE
#3 Posted : Thursday, April 18, 2013 11:20:05 AM(UTC)
BPL-RFE
Thanks Norbert for the Info.
I think what you mention is at least part of the problem MARFUSIO
is reporting [URL="http://forum.punchcad.com/showthread.php?t=4655"]here[/URL].
I am running ViaCAD Pro V8 Build 1017 natively on XP with no big problems.
Roland
