Roger Barrette
#1 Posted : Wednesday, December 5, 2012 9:43:57 AM(UTC)
Roger Barrette
Hi everyone,
How do I get rid the greyed out tab for material in my BOM & Attributes.
I do select my part before & open the Properties table to change the material.
But when I do the BOM Table it does not copy that information onto it.
Any suggestions would greatly be appreciated.
BPL-RFE
#2 Posted : Wednesday, December 5, 2012 1:55:32 PM(UTC)
BPL-RFE
Hello Roger.
1.) in 3D-Mode (NOT Model-to-Sheet) select Part of interest.
Select "Verify -> Properties" and assign Material from List.
Change to Model-to-Sheet Mode and Update BOM to display
Material
2.) refer to Manual Page 123 and following
3.) have you watched this video [URL="http://blog.punchcad.com/index.php/category/tips"]Tip: Adding and Removing BOM Attributes[/URL] (scroll down a little bit) ?
4.) Maybe [URL="http://forum.punchcad.com/showthread.php?t=4069"]these videos[/URL] will help you also ...
Roland :)
Roger Barrette
#3 Posted : Thursday, December 6, 2012 6:58:14 AM(UTC)
Roger Barrette
Thanks Roland,
I have been successful on a few try but not on all. I guess I do not follow the proper sequences & that tends to screw things up.
BTW, I have no idea what manual you are talking about, page 123 talks about viewports on mine
BPL-RFE
#4 Posted : Thursday, December 6, 2012 11:39:06 AM(UTC)
BPL-RFE
Uh oh ....
I was referring to the user Manual for Viacad V8 (I use the Build 1003 Trial)
where you find under Capter 15 "Verify" some explanations for BOM.
Roland :)
