Rick
#1 Posted : Monday, February 28, 2011 11:44:57 PM(UTC)
Rick
Hello everyone. I've recently purchased ViaCad Pro 6. I have a part that I've modeled in 3D that has filleted features. When I turn the 3D model into 2D views using "model-to-sheet" I am unable to dimension the diameters with fillets applied in the appropriate 2D view using any of the radial-out or smart-dimension tools. When I remove the fillet in the visible view, then I'm able to dimension the diameter. If I set the fillet in a hidden area, the radial dimension tool works fine in the visible portion. Please help. I am using ViaCad Pro 6 (build 853) on a Quad Core Mac running OS 10.6.6.
Please see attached screen recording.
mod_2_sheet_dim_prob.mov.zip (1,640kb) downloaded 7 time(s).
mod_2_sheet_dim_prob.vcp (81kb) downloaded 4 time(s).
#2 Posted : Tuesday, March 1, 2011 6:14:12 PM(UTC)
Hi Rick
Can you try reloading movie or some screenshots.
Rick
#3 Posted : Tuesday, March 1, 2011 9:42:06 PM(UTC)
Rick
Hi Jason,
I've re-uploaded a zipped quicktime movie file. Hope this helps.
Thanx,
Rick
#4 Posted : Wednesday, March 2, 2011 11:02:52 AM(UTC)
Hi Rick
I see you movie, can you post the sample file you made the movie with?
Rick
#5 Posted : Wednesday, March 2, 2011 11:31:12 AM(UTC)
Rick
Hi Rick
Here ya go Jason. All I can think of is that it is a bug in this build.
Thanks for your help.
Rick
