Tup48
#1 Posted : Saturday, August 28, 2010 11:57:22 AM(UTC)
Tup48
I have just created a file in ViaCAD Pro. V6, now I would like to convert it to a PDF so anyone without a CAD program will be able to look at it.
Is there an easy way to convert the file to a PDF?
I know that I can export each drawing as a BMP or JPG and then convert it to a PDF but it gets a little distorted.
Richard
#2 Posted : Saturday, August 28, 2010 3:16:04 PM(UTC)
Hi Richard
Are you using Mac or pc?
Set everything up and print the file to pdf. If on pc you can download a free print driver like cutepdf or pdfcreator. Once installed you can choose the pdf driver as the printer. The mac has built in pdf capability.
Tup48
#3 Posted : Saturday, August 28, 2010 4:22:11 PM(UTC)
Tup48
Jason Thanks;
The file converted over perfect.
I already had Nitro PDF Pro. on my computer. This is the first time I know what that print driver was for.
Richard
chipmaker2
#4 Posted : Saturday, August 28, 2010 6:39:44 PM(UTC)
chipmaker2
Install a PDF creator such as 995 and use it as a printer and the program will put out a PDF file. ViaCad 7 comes with "PDF Creator". It installed automatically with one prompt during the installation process of ViaCad 7.
Best to you.
Chuck
