I used to export a DXF with an imbedded SAT file to GibbsCAM. In Ver 5.5 it crashes Gibbs. I can however import a DXF with just geometry and I can import a SAT file. Something happened to the combination export. I'm exporting V13. Patrick
When did Shark 5.5 come out. I've got 5.0.0 which is release 737. Am I missing out here?
It just did Damiane .. but it's a beta so tread carefully
API wrote: I used to export a DXF with an imbedded SAT file to GibbsCAM. In Ver 5.5 it crashes Gibbs. I can however import a DXF with just geometry and I can import a SAT file. Something happened to the combination export. I'm exporting V13. Patrick
Hi Patrick
I made a block with fillet blends and saved as a R13 DXF file. Then imported aok (SAT data preserved) to Inventor LT and DWG TrueView.
Can you check that you have a DXF folder inside your Shark FX 5.5 folder? Do you have read/write access to the DXF folder?
