Solid Modeling
Part rotates back to original attitude (#922)
                I have two cuboids.  I rotate them 90.  I duplicate and mirror one of them and the duplicated part is rotated back.  In the picture I mirrored the small part on the left.  You can see the resulting green part is turned 90.
API attached the following image(s):
(35kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hello Patrick
                Nick,
                API wrote: I have two cuboids.  I rotate them 90.  I duplicate and mirror one of them and the duplicated part is rotated back.
This bug happens all the time... it was mentionned and detailed before on this forum (with attached files).
It's so common that I use the workaround without thinking : stitch the block before rotation or symmetry...
Of course, I loose all history and possibility to modify dimensions of the block...
Time for action ?
                Hello All
Had a look at previous posts and tried to repeat again without success even using sample file provided by JL.  So I'm either completely stupid or it's been fixed in latest development build.  I've uploaded quick movie to our website, as forum seems to be having a problem with it, let me know if I'm doing something wrong...
http://www.cadsoftsolutions.co....movies/rotate_mirror.mov All the best
Nick
                You do it well Nick.
                Nick
                Hello JL
Finally got it to repeat.  It would seem that if rotation is about z axis then rotated block can be copied without issue.  However, if the rotation is about either x or y axes then copies are always transformed incorrectly.  Hopefully this will narrow it down a little for the development team.
http://www.cadsoftsolutions.co.uk/movies/rotate_copy.mov All the best
Nick
                >Finally got it to repeat.  It would seem that if rotation is about z axis then >>rotated block can be copied without issue.  However, if the rotation is >>about either x or y axes then copies are always transformed incorrectly.  >>Hopefully this will narrow it down a little for the development team.
Solid Modeling
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
