paulpiano
#1 Posted : Thursday, March 17, 2011 3:30:57 PM(UTC)
paulpiano
I am having trouble with objects simply disappearing from one day to the next in ViaCAD 6 Mac (build 853). A few days back when I was working on a file, everything was fine, but today when I opened it, a bunch of lines were missing. Funny thing is, I called back the older version from 2 days ago with Time Machine. I hadn't made any changes in the layer containing the group which is now missing a bunch of lines, and comparing the two versions, the object counter says this layer contains exactly the same number of lines in both versions. However, a good 20 or so lines simply are not there. I've tried Select All, Deep Select cursor, ungrouping, changing pen color and width, nothing - they simply are gone. A friend of mine with whom I collaborate on projects (not this one) has been complaining about this for some time, but I thought it was maybe some problem due to the fact that he uses a French language operating system. But no, no I've got it, too!
MacBook Intel Core 2 Duo 10.5.8
#2 Posted : Friday, March 18, 2011 7:15:41 AM(UTC)
Hi Paul
Have you tried "show all"
Have you tried Verify>Object Count (and Check objects)
Have you tried "zoom extents" (e)
Refresh screen (pasta R)
Worth a try : )
paulpiano
#3 Posted : Friday, March 18, 2011 3:18:47 PM(UTC)
paulpiano
Yep, tried all that stuff, no dice.
Here's some screen shots:
http://www.polettipiano.com/CAD/original.tiff
http://www.polettipiano.com/CAD/corrupted.tiff
Interesting thing is that you can see that the object count for both files shows the same number of lines, even though quit a number of them are obviously missing from the corrupted file. Stranger yet, the according to the number of objects for that layer in the Concept Explorer, there are about twice as many objects as the object count menu shows. There's something VERY funky going on here.
More so, it seems to be getting worse. Yesterday, I copied the correct version from the old file and added it as a new layer to the corrupted file. Today I opened it and everything is gone from that layer except for single rectangle. At least the object count menu is correct, it tells me I only have 4 lines. Somehow, that does not instill confidence...
Is it possible for the copy of ViaCAD itself to become corrupted and start doing strange things?
Ciao,
Paul
#4 Posted : Friday, March 18, 2011 3:45:19 PM(UTC)
Sorry to hear that - your build is quite old - not an excuse, but it may be that the issue has been corrected in the meantime
Hopefully Tim will see this thread and comment
paulpiano
#5 Posted : Friday, March 18, 2011 4:25:16 PM(UTC)
paulpiano
Thanks for the hope, if no tangible fix!
Really bad thing is that my colleague who been complaining of the same problem for some time now is still using TurboCAD. We've done a major job together, drawing an antique piano for the collection of the Cite de le Musique in Paris, gong back and forth between Turbo and Via with no real problem except (until now) his disappearing objects. I've been telling him for about a year now he should switch to ViaCAD, 'cause it is not only much better, but doesn't have the disappearing object problem. So I've now got a bit of crow to eat...
Would really like to know if a newer build is available. I like ViaCAD a lot, but this is not fun!
Paul
#6 Posted : Saturday, March 19, 2011 8:38:57 AM(UTC)
Hi Paul
Did you check the help --> current version that should update you to the lasted released build of the version 6 you are running, Version 6 stopped around 853...856. Not sure of exact number.
Do you remember if the lines that are missing are lines that were part of a group? And did the group get copied and pasted from one file to another? And if copied was it copied within the same file with the copy and paste commands or other tools?
paulpiano
#7 Posted : Saturday, March 19, 2011 9:51:18 AM(UTC)
paulpiano
Running build 853, which is the most current.
The first bunch of disappearing lines were in fact part of a group. They were originally created in the layer in which the group still resides. The older version of the file which still has all the lines has them grouped as well. As far as I can remember, there were no changes to that particular layer between versions. The group was duplicated in another layer by means of copy/paste, and then that entire copy was scaled up slightly. Funny thing is, this scaled copy is still intact, while it is the untouched original which has lost some lines.
The most recent catastrophic loss of everything except the outer rectangle was in a copy of the group transferred between files, made by simple copy and paste. I was trying to restore the complete group to the file with the missing lines, so I opened an old version (thank God for Time Machine!), copied the intact group, and then pasted it into a new layer in the file with the lost lines. That process appeared to go fine, everything was there, and I worked with the file for a good half hour thereafter, saving several times, before finally closing it. The next day when I opened it again, Bingo! No lines...
blowlamp
#8 Posted : Saturday, March 19, 2011 10:47:15 AM(UTC)
blowlamp
I'm running ViaCAD Pro v856, so it's possible you aren't on the latest build.
Martin.
paulpiano
#9 Posted : Saturday, March 19, 2011 11:06:05 AM(UTC)
paulpiano
Looks like they did a few more builds for Windows. I'm on Mac. When I select Current Version from the help menu, it tells me i am running the most current version.
NickB
#10 Posted : Saturday, March 19, 2011 3:04:57 PM(UTC)
NickB
Originally Posted by: paulpiano Go to Quoted Post
. . . The group was duplicated in another layer by means of copy/paste, and then that entire copy was scaled up slightly. Funny thing is, this scaled copy is still intact, while it is the untouched original which has lost some lines.
It sounds like many of your losses are related to groups.
My guess is that the group references got messed up, and instead of copying and pasting the group, you somehow moved the group to the new layer. The references are still there, which is why you are seeing the phantom item numbers in the layer manager. This does not explain why some groups / objects would disappear when you re-open a saved file, but it hints that the problem is to do with groups.
Can you change your work-flow to avoid using groups?
For years I have avoided groups because of the infuriating message that I often get when ungrouping:
UnGroup
Would you like to change the group parent to be the same layer as the group? http://forum.punchcad.com/showthread.php?t=3614
My sense is that a lot of grouping problems could be solved by creating a warning message when you group things (particularly if they are on more than one layer) rather than when you ungroup.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Guest (9)
