This thread has gotten out of hand. Can we get back on topic?
There is something very weird about editing extrude data.:confused:
See the attached extrude.vc3
The first extrude in the tree has object info of magnitude ONLY. The second has magnitude and a direction vector!
The first cannot be edited in the object info, the second can!
Sometimes the top menu data entry fields appear, sometimes they don't!
Starting from a clean open of ViaCad, select the model, open concept explorer and the info dialogs. Expand the tree so the two extrudes can be observed. So far NO top menu data entry fields! Select any tool then de-select it. Now select the model again. Top menu data fields appear now.
The numbers in the top menu data entry fields look like extrude data, but don't seem to relate to the item selected in the history tree. They do however modify the selected item! In a very unpredictable way, obviously!
~ o~
Where is the extrude vector for the first extrude? Why can't I edit the object info?
Why does the top menu appear? Why does it allow me to edit anything?
I'm getting very distracted trying to separate the bugs from the learning curve.:mad: (please, please, please a known bugs area)
extrude.vc3
(18kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
