Ryan Anderson
#1 Posted : Tuesday, July 19, 2011 2:19:10 PM(UTC)
Ryan Anderson
I have created a custom model to sheet template in Viacad Pro, and I am trying to use the same template in Shark FX v7sp1, it is not working.
I first saved the template as a .vcp in the sharkv7sp1\templates\modelto sheet. That allowed me to select the template as an option when using model to sheet, which is fine. Clicked okay after selecting scale, and I now have nothing on my screen at all. Concept explorer shows a new layer created for the sheet view, but that layer is completely empty. Click 'edit'-'undo', and some of the template is visible, and clickable (lines, text), but still no objects show up in the concept explorer.
Then I tried opening the file in shark, which worked fine, and saving as an .sfx file to the templates\modeltosheet. Same problem.
I tried exporting the file as v7, v7sp1 but same problem.
I can open the file in Viacad 2d/3d, Viacad Pro, and Shark FX with no errors or problems, but can't get it to work as a template for model to sheet.
Is it the file, or me, or what ?
Ryan
NIMW_2045_A.vcp (70kb) downloaded 7 time(s).
NIMW_2045_D.vcp (83kb) downloaded 5 time(s).
#2 Posted : Tuesday, July 19, 2011 7:20:45 PM(UTC)
Hi Ryan
Try making the title block layer the default layer and resave template. I got it to work by making that change.
Ryan Anderson
#3 Posted : Thursday, July 21, 2011 5:41:44 PM(UTC)
Ryan Anderson
That seems to have worked, thanks Jason
Ryan
