#1 Posted : Friday, February 20, 2009 8:12:18 AM(UTC)
Bounding Box - simplest and best addition for donkeys !
When you make a bounding box .. you are typically doing so in order to see the major dims
Q: Can Bounding box (have an option to) show the major dims automatically - actually on the model ?
... I realise there is a readout at the top - but if your object is near cubic in proportion .. you then need to measure the bounding box edges
ta !
unique
#2 Posted : Friday, February 20, 2009 1:07:16 PM(UTC)
unique
ta !
See attached message shown to the user...have you missed that (no smile) ?
unique attached the following image(s):
#3 Posted : Saturday, February 21, 2009 7:32:05 AM(UTC)
unfortunately the terms "width" & "height" sometimes have no real significance
eg: when you are frequently exchanging data with Solidworks for example or other CAD systems where Y is up by default .. or when laying out parts to cut where z is cut depth, regardless of object orientation
Here, I just want to see my max extents quickly - and then probably delete them !
