Perspective set up - action required (#2142)
where to start ? - perspective checkbox (view properties panel) works to turn perspective on .. but turn it off and it DOES NOT turn off - dialog 'cancel' button does NOT work. If you end up with a space vortex or similar .. cancelling this set-up is not an option .. your stuffed ! - a slider would be much better for focal length .. then you could see things change dynamically .. and perhaps not end up in a SPACE VORTEX - generally, Q: is there not a better way to calculate perspective ? - other apps seem to have perspective that under normal conditions - you needn't change. Perspective in Shark is anas of a thing to set up Like feature select .. maybe there are secrets that I've missed .. but if that's the case then I'm guessing non-techno savvy designers like me will be similarly frustrated Time for change ? God I do hope so ! When are you going to have someone with QA responsibilities? Until you do, users are damned to half finished tools and I am damned to reporting them
