Option - immediately following a rotate command - to flip the rotate direction !? (#1939)
Here's an old request - but a goodie ! It always seemed so logical to me that option would flip over a surface offset, an offset curve and so on .. .. so I've never understood why you don't allow option - immediately following a rotate command - to flip the rotate direction !? I simply always rotate things the wrong way first .. and option-flip would release me from having to go mouse to the toolbar again and type in to negate the rotate number That's all I want for Christmas (well hmmm - there is this perspective thing !)
Jol, Like you this has bugged me for years, and I have always had to mouse to the control panel and enter that -. Then one day I got it. Clock-wise rotations are negative, anti-clockwise positive. Of course there is still the odd exception when things get messed up, but 90% of the time that works. The solution to this age old problem is 3 fold: - Add instructions that tell us which way a rotation will happen, clockwise or anti clockwise. - Add the option key. - Enlarge and change the direction of the tools icon arrow based on the number in the control panel.
Shark FX 9 build 1143
OS X 9.5
matter.cc
doesn't it depend from which direction you're viewing it ?
Thats half the problem, but 99% of the time I use the >Rotate One PointWork Pln Normal< mode so if you know your work plane you are mostly okay.
OS X 9.5
matter.cc
Yes please! Me like option flip! Ciao, Norbert
