I still can't snap the endpoint of a spline to the beginning point of a spline (#117)
I still can't snap the endpoint of a spline to the beginning point of a spline (except when creating it) Snap just ignores it Why ?
jol wrote: I still can't snap the endpoint of a spline to the beginning point of a spline (except when creating it) Snap just ignores it Why ?
Elaborate, it seems to work for me (select end point of spline, drag it to endpoint of another spline, endpoint snap activates)
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
I noticed that snaps are desapearing at high zoom factors. Very often I have to zoom back and use the translate tool. JL
Wmh draw a spline then pick up the endpoint and try to snap it to the start point note: only one spline note also: this is not a problem if you connect it when you make it .. it's a problem when you connect it afterwards
jol wrote: Wmh draw a spline then pick up the endpoint and try to snap it to the start point note: only one spline note also: this is not a problem if you connect it when you make it .. it's a problem when you connect it afterwards
Ah, I got it; tip and tale of same spline. Yes same behavior, no snap to (any) vertex when the spline is being edited. Oddly enough the vertices do come up as constraint points. Doesn't seem to be affected by zoom
