norbertsf
#1 Posted : Sunday, January 31, 2010 2:16:04 PM(UTC)
norbertsf
Is there a command/tool similar to the Linear Array tool that let's one Distribute an indicated number of objects along a line/path? I want to copy a certain # of parts along a line, but want the spacing in between to be determined automatically as a I drag the copies. I don't want to set a spacing dimension. Does that make sense?
Norbert
norbertsf
#2 Posted : Sunday, January 31, 2010 3:56:56 PM(UTC)
norbertsf
Sort of like the "points along curve" command...it has a distribute option...
blowlamp
#3 Posted : Sunday, January 31, 2010 4:42:18 PM(UTC)
blowlamp
Norbert.
Wouldn't that be the Path Duplicate tool?
Martin.
norbertsf
#4 Posted : Sunday, January 31, 2010 9:40:34 PM(UTC)
norbertsf
Ahhhh....will give it a try.
#5 Posted : Monday, February 1, 2010 10:54:53 AM(UTC)
With V7 we also updated this tool to align wrt surface normals if you want to distribute along a surface or solid.
la mouche
#6 Posted : Tuesday, February 2, 2010 2:21:40 AM(UTC)
la mouche
yes Tim, finaly ;)
Antoine
Guest (5)
