mikeschn
#1 Posted : Tuesday, December 14, 2010 5:52:06 PM(UTC)
mikeschn
I've been reading and seeing all your complaints about all the bugs that don't get fixed from version to version, or even from product to product.
So I had a thought.
What if we listed only the single most important bug we'd like to have fixed?
Would Tim focus on that single bug? Perhaps, because thinking about 1 bug is easier than thinking about 100 bugs.
So I suggest that everyone list only 1 bug that they'd really like to see fixed.
Then we can do an analysis of the replies and perhaps offer a suggestion to Tim.
Lets give it a try. List 1 bug you'd like to see fixed... but please, only 1.
la mouche
#2 Posted : Wednesday, December 15, 2010 2:36:11 AM(UTC)
la mouche
less bugs
Antoine
PRP
#3 Posted : Thursday, December 16, 2010 11:15:45 AM(UTC)
PRP
My most unfavored bug is blends inverting inward (typically on multiple blend locations) wherein the display shows white areas as though the solid is a surface with unwanted openings. This results in invalid .stl files.
Another interesting survey would be your most favored NEW feature, the analysis of which should give Punch! a nice, clear picture of priorities.
MacPro quad, 6GB Ram, Wacom Cintiq 21
lebeau
#4 Posted : Thursday, December 23, 2010 4:12:52 PM(UTC)
lebeau
There are just two bugs bugging me right now. The first and priority is the dysfunctional clipping plane. A neat tool but ever since the faces where added, all the lines show up in a clip plane when I show items.
The other, is that when I start shark with another monitor attached the design explorer, snaps, and select mask windows disappear. I have to disconnect the monitor and restart shark.
Mark
#5 Posted : Wednesday, December 29, 2010 5:16:02 AM(UTC)
draw an interpolate spline such that the end meets the start ... mMmm nice smooth curve results !
now .. undo last and then redo
your nice smooth curve now has a kink - and if like mine it's a driving curve ... there's no obvious way to recover than starting again
redo must always recover the pre-undo state ... otherwise it's not redo
