mikeschn
#1 Posted : Sunday, November 21, 2010 12:36:20 PM(UTC)
mikeschn
How do I get rid of that blocky feeling?
Below is a picture of that blocky feeling... notice the lug nuts are little blocks...
After a while they finally look like lug nuts again...
How do I make that happen faster?
I'm running on a quad-core laptop with ATI Radeon HD 4650 graphics.
Mike...
#2 Posted : Sunday, November 21, 2010 5:14:13 PM(UTC)
Hi Mike
View Shade options
Dynamic level of detail lower is more detail.
shade options.PNG (11kb) downloaded 6 time(s).
mikeschn
#3 Posted : Sunday, November 21, 2010 6:48:45 PM(UTC)
mikeschn
so if I set it to 0 will I always have full detail?
Mike...
NickB
#4 Posted : Sunday, November 21, 2010 9:38:32 PM(UTC)
NickB
I generally set it to 1.0 or 1.5.
1.0 is the default for static detail so why set it lower than (finer) than you can display ?
Unfortunately, at least on a Mac the setting needs to be re-set ever time that you launch Shark as it is not saved with the file, and there does not appear to be any way to set it as a global preference. Either this is a bug, or an oversight.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Jean-Francois Jacques
#5 Posted : Monday, November 22, 2010 4:06:35 PM(UTC)
Canada
Nick,
On your PC your value stay like the default? Like you said not on the Mac.
I ask to Tim for a long time that is a problem!!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
