mikeschn
#1 Posted : Monday, February 7, 2011 4:36:24 PM(UTC)
mikeschn
Lets say I've drawn a bunch of lines in model space, and added them to a drawing, using the model to sheet function.
Suddenly I realize there's a couple lines I don't want in my view...
Is there any way to remove the lines from the view, without removing them from the model space?
I've tried removing it via the inspector, like one would remove a solid part, but that doesn't work. UserPostedImage
Mike...
NickB
#2 Posted : Monday, February 7, 2011 6:59:34 PM(UTC)
NickB
Can you flatten the drawing (and loose associativity) then delete the lines ?
Shark FX 9 build 1143
OS X 9.5
matter.cc
mikeschn
#3 Posted : Monday, February 7, 2011 7:09:22 PM(UTC)
mikeschn
I would prefer to keep the drawing views, rather than flatten everything.
Mike...
mikeschn
#4 Posted : Tuesday, February 8, 2011 11:08:51 AM(UTC)
mikeschn
No other suggestions? :confused:
Mike...
#5 Posted : Wednesday, February 9, 2011 10:24:20 AM(UTC)
>>Is there any way to remove the lines from the view, without removing them >>from the model space?
If the lines are the result of a hidden line calculation, you can select and hit the delete key. If they were originally curves, then they will get deleted in model space as well as you noted. I will need to look into an option to delete just from a view.
#6 Posted : Wednesday, February 9, 2011 1:36:51 PM(UTC)
Y' know, I've not really explored mode-to-sheet much. But, my off-the-cuff thinking is to wonder if it is possible to open a viewport or to switch to the basis view and select and hide objects or flag them with some appropriated attribute, then regenerate the model-to-sheet view.
jube
#7 Posted : Wednesday, February 9, 2011 7:48:09 PM(UTC)
jube
What if you were to go to layers and delete the sheet layers? Of course you would have to redo the model to sheet without the lines that you don't want. Not an expert but worth looking into?
Dev
#8 Posted : Thursday, February 10, 2011 10:33:13 AM(UTC)
>>Is there any way to remove the lines from the view, without removing >>them from the model space?
Mike,
Give it a go again in 962.
http://www.csi-concepts.com/Demo/videos/auxviewdelete.mp4
In addition to using the Edit:Cut, you can just select and hit the delete key.
#9 Posted : Thursday, February 10, 2011 1:15:43 PM(UTC)
>>Has build 962 been released?
No, but should be ready this weekend.
mikeschn
#10 Posted : Tuesday, February 15, 2011 5:07:28 PM(UTC)
mikeschn
Build 962 fixes the deleting curves from view problem!
Thanks Tim! Now I can start working on my drawings! UserPostedImage
Mike...
