Solid Modeling
Modeling a pitman arm (#2799)
I only have Viacad 2d/3d. I was wondering, how one would model a pitman arm using VC. I am especially interested in how you would handle the 7 draft on the sides, since VC2d/3d doesn't have the draft command.
I've attached a sample drawing that you can use as a starting point.
Let's have some fun with this one... and share your models...
Mike...
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
I'm thinking you want the tapered hole for the ball stud, Draw a half tapered rectangle with the 1 1/2" per foot taper. Do a lathe solid, move to position on the end of the arm, and subtract solid from the arm. Hope this helps, time is tight today, Merry Christmas. Larry
Originally Posted by: L. Banasky I'm thinking you want the tapered hole for the ball stud, Draw a half tapered rectangle with the 1 1/2" per foot taper. Do a lathe solid, move to position on the end of the arm, and subtract solid from the arm. Hope this helps, time is tight today, Merry Christmas. Larry
That may be true, but I was playing with the forging, not the machining... actually I am just interested in how the outside of the model is best created in VC.
Mike...
Mike
here is a quick crack at it...
parmji.vc3
(1,330kb) downloaded 5 time(s). jdi000 attached the following image(s):
(44kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Good model Jason... double rail sweep! I like it... I especially like that you added the blend radii to the parting line! Any other ideas? Maybe a loft? Mike...
Originally Posted by: mikeschn Good model Jason... double rail sweep! I like it...
One of the problems with sweeping is possible self intersecting or distorted surfaces. That will probably be why Jason has added rads to the leg, rather than attempting to creating sharp corner intersections
If you look at the model posted by Jason, you can see some distortion of the sweep surface.
I think, if those sharp corners are required, then it would be easier to create sections along the sweep profile and use skin solid.
I will have a play.
- Steve
Found time to have a quick play. Modeled as drawn.
(32kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Mike,
A quick mov to show the model above. Nothing fancy in the modeling, just done to produce the model quickly/easily(I used VC pro, but used only tools available in 2d/3d)
Move direct download Model file download - Steve
Very nice Steve, I would have never thought of splitting the model to change the elevation of the bosses. Good job on that! And thanks for sharing that movie. I have off all of next week, so I am thinking about trying the movie thing too! Mike...
Solid Modeling
