Mogal
#1 Posted : Friday, March 21, 2014 9:05:26 AM(UTC)
Mogal
How do you reset the axis after you rotate an object?
(please see pic)
Also, I have an STL that I'd like to change to a solid.
I get the error "Maximum number of facets is 2000"
Its in meshes right now.
Mogal attached the following image(s):
#2 Posted : Friday, March 21, 2014 9:56:34 AM(UTC)
The Reset Axis button in the Gripper Settings of Inspector.
zumer
#3 Posted : Friday, March 21, 2014 3:06:50 PM(UTC)
zumer
I was doodling with converting to solid from primitives in FX9 1109 and discovered that it returns that "less than 2000" faces error even when there are less than 2000 - for spheres. When I tried it with some other blocks, cones and cylinders, no notification appeared, though some had many more than 2000 faces.
Mogal
#4 Posted : Thursday, March 27, 2014 9:19:21 AM(UTC)
Mogal
I don't have those options?!
UserPostedImage
No reset.jpg (59kb) downloaded 4 time(s).
rockyroad_us
#5 Posted : Thursday, March 27, 2014 9:33:06 AM(UTC)
rockyroad_us
It is under the pull-down menu Attach. Select user-positioned you'll see more options.
