Mogal
#1 Posted : Friday, May 9, 2014 9:31:26 AM(UTC)
Mogal
Hello!
I've been making good progress in my learning curve over the last couple of weeks, but I'm still having troubles with modifying parts.
I'm making this pulley set-up, and need to adjust the spacing on the pulleys as the cables are touching.
They are spaced at 1mm. The left pulley at the even mm the right pulley at 0.5mm spacing. The cable is 0.48mm
Whats the best(easiest)way to increase the groove spacing to 1.5mm instead of 1mm?
I attached my working file. (sorry for the large pics)
UserPostedImage
UserPostedImage
UserPostedImage
pullies.vcp (1,170kb) downloaded 9 time(s).
Mogal attached the following image(s):
Mogal
#2 Posted : Friday, May 9, 2014 5:01:49 PM(UTC)
Mogal
Okay, I got it... was easier then I thought it would be.
