Ok, I've been having issues with ViaCAD all night.
From unknown crashes, to not being able to save my files!
I also keep getting ACIS errors... whatever they are?
and Viacad is currently using 1.7gigs of memory!!!!!
(the saved files I do have are under 20megs)
There are times when I go to use the push/pull tool, and the program
hangs for 2-3 minutes before it become responsive again.
The program is lagging really bad and so slow to respond.
My biggest problem right now, is I can not save my file!
even the backup come back with an error of unable to save.
I must say, I really like ViaCAD, its so intuitive, and easy to use(when it works)
...but the stability is horrible :mad:
My build is 984. Is there a newer build available?
How do I go about getting it?
I'm running windows7 64bit, and notice Viacad is 32bit.
Although my laptop is WinXP 32 bit, and has the same issues.
Mogal attached the following image(s):
(49kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
