mlochala
#1 Posted : Wednesday, February 24, 2010 12:04:04 PM(UTC)
mlochala
I have been working on a rather complex (for me) project and have run into an issue when assembling the overall model with various modeled components and sub-assemblies.
For example, my model has a particular bolt and washer combination that I modeled in a separate file and then grouped together. When I imported it into the assembly file, I had two problems when placing it into position.
First, I can't seem to get the Mate Faces/Hole (can't exactly remember the name of the tool) with the group, which consists of a Allen-type bolt, a seat washer and a brass-like washer. Will this function not work with Groups, or is that for a single part only?
Secondly, when nudging the group into position, I had some inexplicable issues with one of the washers that decided to ungroup and relocate itself into another position elsewhere in the model. What causes this to happen, and how can I avoid it in the future?
With regard to this specific problem, I was able to get the assembly together finally, but was just curious if this is a known problem or am I doing something to cause this? Is it some sort of associative thing?
#2 Posted : Wednesday, February 24, 2010 1:23:06 PM(UTC)
I have seen on build 852, that grouped 3d objects when using translate tool, or undo after translating the group regenerates but some of the objects in the group move to a previous location instead of the location the group was moved or nudged to.
Art
#3 Posted : Monday, March 1, 2010 2:55:06 PM(UTC)
Art
Perhaps this has something to do with the generating forms. For example, if you use a circle to make a cylinder you must move both at once.
Could this be it?
Art
OSX Shark FX 853
#4 Posted : Monday, March 1, 2010 5:22:51 PM(UTC)
Could this be it?
Art
OSX Shark FX 853
Art
I think you are right. My question is, ... is this behavior necessary? Why allow someone to move objects with dragging anywhere, then when using the translate tool the objects regenerate and move back to there created positions.
Would it not be better to be able to translate the geometry, and underlying curves separately if wanted... especially when working with assemblies...
Art
#5 Posted : Monday, March 1, 2010 7:11:13 PM(UTC)
Art
That is a good point. It seems to me the default Should be to translate the underlying geometry. This sure would make my CAD life easier. I spend a fair amount of time "removing links" to make sure that I don't get endless cycles between regeneration.
Does this make sense to others?
Art
OSX Shark FX 853
Art
#6 Posted : Tuesday, July 26, 2011 3:47:10 PM(UTC)
Art
This is still happening in FX 967. I try to rotate a group and some parts rotate one way and some another.
These are imported step parts with no history, so it is not a matter of moving generating geometry as mentioned above.
Anybody know why this happens? BTW, UNDO will not fix the problem, it is like a mini crash.
Art
Shark FX 967
10.6
Tem
#7 Posted : Saturday, July 30, 2011 2:04:12 AM(UTC)
Tem
A mini crash? The Mini is a very small car, are you sure it's not a fatal crash?
Dark humor aside, it's a failure. If the behavior is inconsistent in this way it might as well be considered a real crash. I have experienced similar anomalies, and forget to make bug reports sometimes.
I think that it would be better to drop history on parts imported into an assembly, unless there could bs a part based on am assembly of other parts which adds a level of complexity (how to to deal with associations when other parts in an assembly change).
It's too late, good night!
Art
#8 Posted : Saturday, July 30, 2011 9:15:06 AM(UTC)
Art
That is my concern; these are parts with no history or associations, yet they still break apart.
Art
Shark FX
10.6
Guest (6)
