Proper way to find out Weight? (#3269)
In 5.5 fx, I can figure out length, area, volume, and under properties one can figure out mass easily based on material. Is there a way to determine weight easily? Thanks!
Hi misterrogers
Use Verify --> Properties
And enter the correct density of the object and the weight is calculated.
(49kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks Jason. Volume I know of course since I have that info, but for example, if a product is comprised of solid kiln-dried pine, how would you determine the density? I don't know it's moisture content. Is there a standard table of densities for 1m3 of various wood types somewhere out there?
