Can you subdivide a face or "split" a face in Shark FX? I want to change the color of part of a face for rendering in Keyshot.
Project a curve onto a surface with the option to embed. Once the curve is projected you can then convert surface via type to surfaces. The surface becomes split at the projected curve as long as the curve acts a boundary.
Originally Posted by: rockyroad_us Project a curve onto a surface with the option to embed. Once the curve is projected you can then convert surface via type to surfaces. The surface becomes split at the projected curve as long as the curve acts a boundary.
Thanks Rockyroad, I'll try this.
It would be nice in the future, to simply deep select a face and split the face with two points.
Originally Posted by: jjeconomaki If all you want to do is manipulate the face for rendering purposes and not mess with your engineering geometry, you can offset a new face with a very small offset (.01mm) and do what ever you want with the sacrificial face and then assign colors. -John
Don't know why I didn't think of this before. Thanks John!
