Art
#1 Posted : Thursday, December 27, 2007 11:44:45 AM(UTC)
Art
I believe I mentioned this in the old forum (pre-punch). When you zoom in, the construction lines disappear.
Don't want to let these old bugs disappear either!
BTW "Is this solved in Shark?" (Guess that should be my mantra, pre-release)
Art
#2 Posted : Friday, December 28, 2007 8:30:37 AM(UTC)
Art
A number of weird things happen with Construction lines
Particularly switching from WF mode to Shaded mode & back
Looking forward to seeing a slick fix in Shark !
#3 Posted : Friday, December 28, 2007 11:55:37 AM(UTC)
Art, fixed it today, thanks for bringing up. The correction is in build 735.
Art
#4 Posted : Saturday, December 29, 2007 10:12:27 PM(UTC)
Art
Thanks Tim,
Did you also fix the bug that you can't select while zoomed in? That is much more serious.
Art
Macintel
#5 Posted : Monday, December 31, 2007 1:29:34 AM(UTC)
Art,
If it is still doing it in 734 then no. Do you have a sample file?
Art
#6 Posted : Monday, December 31, 2007 8:19:58 AM(UTC)
Art
Tim,
I am using 668. I don't think you need a sample file, make a block, just zoom in until you can't select anything. it is very consistent and has been happening on every version, every drawing that I have tried.
Art
MacIntel
#7 Posted : Monday, December 31, 2007 11:49:13 AM(UTC)
Tim .. I'm on 668
Metric
I zoom in on a cube till a 1mm line is about a qhater of my screen
I then cannot select the cube
Hope you can rpt ?
Art
#8 Posted : Monday, December 31, 2007 3:33:35 PM(UTC)
Art
Here is a file and a movie to demonstrate. As you can see, the file is fairly simple. The movie shows me zooming in twice and not being able to select.
I am constantly working around this.
Art
MacIntel
Cantselect.cu (9kb) downloaded 4 time(s).
Cantselectmov.zip (81kb) downloaded 4 time(s).
ianjkirby
#9 Posted : Monday, December 31, 2007 9:12:35 PM(UTC)
ianjkirby
Hello Tim,
This is the second note in this thread where you refer to "734" as though it is in service. I just read moments ago in another thread that build 734 will happen soon, implying it is not in use yet. Are you talking about the same thing here, or do the two references to "734" mean different things? Sorry if I appear slow on the uptake here, but I am not certain I am interpreting things correctly.
Regards, Ian Kirby.
Wollongong NSW Australia
Ian Kirby
Wollongong Australia
#10 Posted : Monday, December 31, 2007 10:29:26 PM(UTC)
Hi Ian,
We are currently beta testing Shark FX Build 734. You are welcome to beta this product at:
http://www.csi-concepts.com/sharkbeta.htm
The ViaCAD 2D/3D update will be derived from this build.
#11 Posted : Tuesday, January 1, 2008 9:40:32 PM(UTC)
Art, I'm pretty sure I've got this now fixed in 735 (thanks for the files). It was an integer rounding issue due to zooming way in. If you can confirm its fixed in the next build that would be great.
