misterrogers
#1 Posted : Sunday, September 13, 2009 2:58:32 PM(UTC)
misterrogers
I am trying to rotate a wood grain texture in a rail to orient the grain horizontally (along the length of the rail) rather than vertical. Can anyone please tell me if this is possible and if so, how to go about it?
Thank you!
Steve.M
#2 Posted : Monday, September 14, 2009 5:07:44 AM(UTC)
Steve.M
Hi misterrogers,
Is that for Shark FX for photo render?
You can change the way the texture is applied by changing the Texturespace of the object.
To do that, bring up the "Render Material settings" (right click the object and select "Photo Render" -> "Edit material"). In the popup window (see pic), select "Texturespace" (in the top left drop down list), you can then change the texture to the various axis etc.
misterrogers
#3 Posted : Monday, September 14, 2009 8:24:05 PM(UTC)
misterrogers
Thank you Steve! Yes it is for Shark FX. I will try that right away.
regards
