misterrogers
#1 Posted : Saturday, October 10, 2009 2:13:38 PM(UTC)
misterrogers
Sometimes upon re-opening an existing file, I notice that most of the lines and curves from within an object are mysteriously missing.
Is this a known issue or is this something that I might be doing wrong?
misterrogers
#2 Posted : Monday, October 12, 2009 8:05:49 PM(UTC)
misterrogers
Anyone? Bueller? I did discover that this problem seems to happen ONLY on grouped objects that have multiple curves.
#3 Posted : Tuesday, October 13, 2009 1:47:28 AM(UTC)
.. Fry !
Nope - no idea
Can you be more specific ?
Are you sure they aren't hidden / relayered or something ?
Are you using the Select Mask - that catches me out frequently !
misterrogers
#4 Posted : Thursday, October 15, 2009 9:10:39 PM(UTC)
misterrogers
i think you're suggestion is well worth looking into.. i will investigate this further.. if no one else has experienced this, then it is very likely that i am doing something simple that's causing it in the first place.
ttrw
#5 Posted : Friday, October 16, 2009 7:07:25 AM(UTC)
ttrw
Bring up the show all palette too. It's often hidden when you first open the app.
Guest (5)
