misterrogers
#1 Posted : Saturday, March 13, 2010 4:22:24 PM(UTC)
misterrogers
I need to show a hole for a pocket screw at the end of a board.
Can someone kindly show how to model this? Or at least what tool to use? I tried the countersink, counterbore and reg hole but can't figure out how to angle the through-hole to the perpendicular attached face. Thank you.
misterrogers
#2 Posted : Saturday, March 13, 2010 4:46:16 PM(UTC)
misterrogers
Here's an example of what I'm trying to accomplish:
misterrogers attached the following image(s):
pocket screw.jpg (44kb) downloaded 5 time(s).
NickB
#3 Posted : Saturday, March 13, 2010 7:00:56 PM(UTC)
NickB
Try drawing a centerline for the hole that you want - extend it a bit on either end. Then use the C key to create a work plane on one end of that line perpendicular to the direction of the line. Draw a circle of the diameter that you need for the hole, then use the extrude hole tool create the hole.
Hope this is clear enough.
screenshot 03.png (39kb) downloaded 5 time(s).
Shark FX 9 build 1143
OS X 9.5
matter.cc
misterrogers
#4 Posted : Saturday, March 13, 2010 11:07:01 PM(UTC)
misterrogers
That's it. I was thinking to use one of the tools i mentioned earlier, but I guess a hole is well.. a hole. None of them seemed to be able to angle to a specific point on a face but this does the trick. thanks!
#5 Posted : Sunday, March 14, 2010 4:38:41 PM(UTC)
Hi
Try the 2pt option and then you can draw your hole, countersunk, counterbore at an angle to a face, you can draw a center line to use as a guide.
misterrogers
#6 Posted : Monday, March 15, 2010 3:23:04 PM(UTC)
misterrogers
Hi
Thanks Jason, I thought there might be a way using one of those tools.
