How to put "pocket screw" hole in solid? (#3071)
I need to show a hole for a pocket screw at the end of a board. Can someone kindly show how to model this? Or at least what tool to use? I tried the countersink, counterbore and reg hole but can't figure out how to angle the through-hole to the perpendicular attached face. Thank you.
Here's an example of what I'm trying to accomplish:
misterrogers attached the following image(s):
(44kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Try drawing a centerline for the hole that you want - extend it a bit on either end. Then use the C key to create a work plane on one end of that line perpendicular to the direction of the line. Draw a circle of the diameter that you need for the hole, then use the extrude hole tool create the hole.
Hope this is clear enough.
(39kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Shark FX 9 build 1143
OS X 9.5
matter.cc
That's it. I was thinking to use one of the tools i mentioned earlier, but I guess a hole is well.. a hole. None of them seemed to be able to angle to a specific point on a face but this does the trick. thanks!
Originally Posted by: misterrogers That's it. I was thinking to use one of the tools i mentioned earlier, but I guess a hole is well.. a hole. None of them seemed to be able to angle to a specific point on a face but this does the trick. thanks!
Hi
Try the 2pt option and then you can draw your hole, countersunk, counterbore at an angle to a face, you can draw a center line to use as a guide.
(34kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jdi000 Hi Try the 2pt option and then you can draw your hole, countersunk, counterbore at an angle to a face, you can draw a center line to use as a guide. Regards Jason
Thanks Jason, I thought there might be a way using one of those tools.
