Art
#1 Posted : Friday, December 14, 2007 6:56:11 AM(UTC)
Art
When I try and match a surface to a cylinder the object extends to the farthest point (on the "other" side). This happens even if I split the cylinder and get rid of the "other side" (which is pretty freaky).
Is there a way to deal with this? There seems to be no way to match surfaces to the closest surface, is that right?
Thanks in advance,
Art
MacIntell
HEY, I'm a member! Woo Hoo!
Art
#2 Posted : Thursday, December 20, 2007 1:11:57 PM(UTC)
Art
Here is a movie of the problem in another form. The surface I am trying to match to is spherical.
What seems to be happening is that the surface is extending to some non-existent other side of the sphere.
Art
MacIntel
MatchFace.zip (44kb) downloaded 5 time(s).
nick
#3 Posted : Friday, December 21, 2007 4:04:12 AM(UTC)
nick
Hello Art
Just a thought but what happens if you rotate cylinder through 180?
All the best
Nick
Art
#4 Posted : Friday, December 21, 2007 7:32:50 AM(UTC)
Art
Nick,
That is a good thought, certainly as an experiment. But, on the cylinder, the extension goes to both sides (so rotating would look the same). On the sphere on the other hand, it just seems to go the wrong direction, so the rotation should give me something on the right surface. On the other hand, if you look at my movie, there is a revering or somthing that happens at the sphere origin...it is all very messy.
Thanks for the response,
Art
#5 Posted : Saturday, December 22, 2007 2:39:52 PM(UTC)
Can you post the actual file?
Art
#6 Posted : Thursday, December 27, 2007 3:48:56 PM(UTC)
Art
Here is one example. This happens to be extending a spherical shape but I have had this problems extending to and from spheres and cylinders. To me, a pretty serious problem. Try to extend the surface highlighted in blue to the surface highlighted in green. What I get is a big hoop. I have this problem on all sorts of files. This is actually a more complex example.
Art
MacIntel
matchface.cu (40kb) downloaded 5 time(s).
#7 Posted : Friday, December 28, 2007 8:41:07 AM(UTC)
Yes .. these hoops are a huge pain - I think they may be an acis problem - but who knows
I'm getting these hoops often when exporting to SolidWorks - presumably when a surface doesn't get trimmed back right
Be great to collect some 'cases' of this - think I got one or two in my modestly proportioned :| folder entitled 'CUFUs'
Art
#8 Posted : Monday, February 18, 2008 1:04:27 PM(UTC)
Art
Was this bug repaired in Shark? Here is my latest movie (and file).
Isn't this a simple problem?
Art
Mac 10.4 CU668
Bad extension.cu (31kb) downloaded 5 time(s).
ScreenSnapz.zip (104kb) downloaded 5 time(s).
nabed
#9 Posted : Tuesday, February 19, 2008 7:28:53 AM(UTC)
nabed
I can confirm that this happens quite frequently (though apparently in a random manner) and can be very annoying!
Ciao, Norbert
Art
#10 Posted : Tuesday, February 19, 2008 7:42:40 AM(UTC)
Art
Do you mean it is still in Shark?
Art
nabed
#11 Posted : Thursday, February 21, 2008 9:47:44 AM(UTC)
nabed
Sorry for the misunderstanding, I'm still using CU 4.
Ciao, Norbert
Art
#12 Posted : Thursday, February 21, 2008 9:57:12 AM(UTC)
Art
No Misunderstanding, I am using CU4 as well. I just wanted to know if it had been addressed. I just bought Shark and I was hoping that this was one of the issues solved.
Art
Guest (11)
