angular constraint? (#3820)
is there currently a means to constrain by angle?
I believe what you are looking for is to put a dimension constraint on your angular line, and then edit the dimension.
Mike...
(15kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: mikeschn I believe what you are looking for is to put a dimension constraint on your angular line, and then edit the dimension. Mike...
Thanks Mike, but I guess I don't understand completely.
Exactly what dimension constraint do I add to my angular line(s)? Auto? Smart? And is it to both lines or just one?
If you could post a quick video it would help my feeble mind tremendously.
Thanks! :)
excellent!! merci ! Antoine
Thanks for the video - your constraint tutorials are welcome anytime in my opinion. I wouldn't have guessed to lock the bottom line.
You're welcome Misterrogers! Mike...
