misterrogers
#1 Posted : Monday, February 20, 2012 4:37:49 PM(UTC)
misterrogers
Not sure if I worded my question right, but I want to be able to correctly notate drilling specs and often they require two lines of text.
For example, for a countersunk hole I'll write the first diameter on top, and then use the A (Text) tool to write below it the rest of the second diameter and CSK angle.
So.. is there a way to notate this such that it's all contained in one text block?
#2 Posted : Monday, February 20, 2012 6:52:50 PM(UTC)
You can add a second line to a text string by inserting a \P into the text string.
misterrogers
#3 Posted : Tuesday, February 21, 2012 10:08:58 AM(UTC)
misterrogers
And it's that easy! Thanks Tim.
la mouche
#4 Posted : Tuesday, February 21, 2012 10:11:23 AM(UTC)
la mouche
hello,
it's possible to see a example, please?
Antoine
PRP
#5 Posted : Wednesday, February 22, 2012 5:52:39 PM(UTC)
PRP
Hello Antoine,
Very happy to give you a video after watching all of your wonderful tutorials !!
Best Regards,
Paul
2 LINE TEXT.mov (1,624kb) downloaded 5 time(s).
misterrogers
#6 Posted : Friday, February 24, 2012 8:17:51 AM(UTC)
misterrogers
Curiously, when I opened an exported DXF and DWG file from Shark - in 2 versions R14 & 2007-2009 - the text showed up with the \P tag and became one-line instead of several. I opened them in the latest Draftsight if that makes a difference.
Is this string or tag only useful in Shark? Here's a snap shot of one of them..
Also, ARROWS show up in Draftsight as just lines without arrow-heads. Is there a format that I can export to that will fix this?
misterrogers attached the following image(s):
Opened in Draftsight Bad Text.jpg (26kb) downloaded 5 time(s).
misterrogers
#7 Posted : Friday, March 2, 2012 11:01:03 AM(UTC)
misterrogers
Anyone? Anyone? Bueller?
#8 Posted : Sunday, March 4, 2012 8:35:02 AM(UTC)
Hi misterrodgers
The \P goes back to autocad, I would guess that Draftsight does not support. A test I open in Dwgtrueview program shows the file exported from ViaCAD as 2007 dwg.
The arrow files might be a formatting in draftsight as well. Don't know what arrows you used? Maybe try different arrows?
dwg test.PNG (33kb) downloaded 5 time(s).
misterrogers
#9 Posted : Sunday, March 4, 2012 11:55:03 AM(UTC)
misterrogers
Thanks Jason - I don't own a license of Autocad so I can't open it in it. I'll experiment with different arrows though. I guess in this era, one hopes and expects that most applications are 100% compatible amongst one another regardless of maker.
la mouche
#10 Posted : Monday, March 5, 2012 1:40:09 AM(UTC)
la mouche
oohh! thanks Paul :)
Antoine
