Solid Modeling
Error when blending edge (#4220)
I get this error message when trying to round the edge by 1mm (its a 15 mm panel). Not complex geometry at all merely a simple extruded profile.
Any ideas what I can do to resolve this? Thanks.
misterrogers attached the following image(s):
(47kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
I think you need to select the edges individually around the perimeter. Not sure what is causing this.
Thanks but I just tried that and here's a new message I got. No idea what this means..
(16kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I can't make out what you're doing from the pics. Can you post the file for us to look at? Martin.
Okay here's the panel in question.
paneltoblendedge.sfx
(74kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I would redo the profile. There's a small kink on the upper left side which is too small to detect. Another way to check this problem is to check the draft angle. :eek:
Also, with your original profile make sure you have continuity especially with the slopes at the meeting curves. When I broke the solid to lines I get a lot of slopes going at different directions.
Thanks, I will redo the curves. The profile was given to me in an adobe illustrator file which I imported into shark and extruded. I probably should have redrawn it and thus mitigated any of those wonky errors..
Solid Modeling
