misterrogers
#1 Posted : Monday, June 11, 2012 3:24:17 PM(UTC)
misterrogers
Occasionally in Shark v8, hitting the spacebar doesn't do anything. It's as if the pan suddenly stops working, whether in 2D or 3D mode.
I can't figure out what I'm doing that occasionally causes it. Caps lock is off, I'll try to quit and re-start and it will still be broken. It seems that if I stay away from the program (just minimized) and go do something else for a little while in another program it'll start working again.
Has anyone come across this?
#2 Posted : Tuesday, June 12, 2012 2:56:25 AM(UTC)
is this just in the latest builds - or more generally ?
(I haven't seen it)
misterrogers
#3 Posted : Tuesday, June 12, 2012 7:22:30 AM(UTC)
misterrogers
Jol, I think it might be something to do with what other programs I have open and in front that also make use of the space bar. Something for some reason is interfering. I had firefox, entourage, openoffice, and ical open yesterday. But I can't figure out which if any is causing it. It'll sort of go away on it's own after a minute or two. I'll let you know if I come across anything specific that i'm doing, but so far just ordinary operations.
