myoung
#1 Posted : Saturday, March 31, 2007 7:40:55 AM(UTC)
myoung
Hi Tim,
[Intel Mac] When I use the lathe tool on a single profile, everything is dandy. But if I try multiple profiles, it doesn't work. If the profiles are separate, sitting next to one another, CU does nothing. If the profiles are concentric (they would extrude a walled shape, like a pipe), CU tells me something dire happened, partially locks up, then crashes.
myoung
#2 Posted : Saturday, March 31, 2007 7:48:32 AM(UTC)
myoung
Interestingly, if I have two profiles side-by-side and try to lathe them (an ellipse and a circle, for example), after I select the axis, nothing seems to happen.
But then if I use the selection tool and drag one of the profiles onto the other one, suddenly the lathe tool fires up and I get two overlapping extrusions.
#3 Posted : Saturday, March 31, 2007 12:43:12 PM(UTC)
Sure enough, repeats here as well. Will look into.
