workshopswarf
#1 Posted : Saturday, December 15, 2012 6:30:10 AM(UTC)
workshopswarf
Sudenly I am getting a runtime error and have to close the drawing when I am using the callout balloon dimentioning. Anything I can do to cure this?
workshopswarf
#2 Posted : Saturday, July 20, 2013 2:14:13 PM(UTC)
workshopswarf
Lots of views but no answer. Problem still exists, I am using XP . I am considering buying another copy of Viacad to run on another machine on Windows 7. Does anyone else have this problem and would switching to Win7 cure it?
#3 Posted : Sunday, July 21, 2013 6:11:23 AM(UTC)
hi david,
what build of the program are you using?
workshopswarf
#4 Posted : Sunday, July 21, 2013 12:17:22 PM(UTC)
workshopswarf
Hi Jason, Build is 968
posh.de
#5 Posted : Monday, July 22, 2013 5:05:19 AM(UTC)
posh.de
Originally Posted by: workshopswarf Go to Quoted Post
...a runtime error... Anything I can do to cure this?
you can post the exact/full error message sothat a problem evaluation might be possible.
Norbert
workshopswarf
#6 Posted : Tuesday, July 23, 2013 1:45:46 PM(UTC)
workshopswarf
Norbert,
I decided to take the bull by the horns and purchased a v8 upgrade which I have installed on another PC running Win 7 so problem should be solved but for your information, from memory,the error report mentioned C++.
posh.de
#7 Posted : Wednesday, July 24, 2013 4:54:57 AM(UTC)
posh.de
...the error report mentioned C++.
than maybe the [URL="http://www.microsoft.com/de-de/download/details.aspx?id=3387"]MS Visual C++ 2005 x86 Runtime installation[/URL] - which is launched by the VC/SFX setup during installation - has failed, maybe because of missing user rights especially under W7/8.
running the VC/SFX setup by "right-click > run as admin" should avoid this type of problem.
hth,
Norbert
