martinwh99
#1 Posted : Monday, August 20, 2012 1:33:07 AM(UTC)
martinwh99
Switzerland
Hello
I have a problem with extrution. Can someone please tell me why this file does not extrude correctly. Thanks
kind regards
Martin
ViaCAD v8.0.0 Build(1007)
yw-front.vc3 (199kb) downloaded 4 time(s).
Martin Krueger
ViaCAD ProV9, Cut2D, Cut3D
billbedford
#2 Posted : Monday, August 20, 2012 2:09:18 AM(UTC)
billbedford
What do you mean by extrude correctly?
Is this what you were looking for?
billbedford attached the following image(s):
martinwh99
#3 Posted : Monday, August 20, 2012 2:42:46 AM(UTC)
martinwh99
Switzerland
Yes. But this is how it looks if i do it. What have i done wrong?
martinwh99 attached the following image(s):
Martin Krueger
rockyroad_us
#4 Posted : Monday, August 20, 2012 8:19:12 AM(UTC)
rockyroad_us
I get a different result. Only the outer perimeter got extruded.
So I projected everything on the plane using the project to plane command and that worked for me.
I didn't project the small square with its holes only the perimeter and the 5 holes.
billbedford
#5 Posted : Tuesday, August 21, 2012 3:05:48 AM(UTC)
billbedford
It looks as if you have not selected all the line segments. Try selecting one line in the outline and then 'Chain Select' from either the Edit Menu or the Context Menu.
martinwh99
#6 Posted : Wednesday, August 22, 2012 7:01:59 AM(UTC)
martinwh99
Switzerland
Thanks allot that was the solution. Now everything works fine.
Martin
Martin Krueger
Guest (5)
