Martin K
#1 Posted : Tuesday, April 17, 2007 8:38:34 AM(UTC)
Martin K
Hi folks, any one have a good route into Cinema 4D? I've been using dxf with patchy results...
Martin K
joev
#2 Posted : Tuesday, April 17, 2007 8:54:40 AM(UTC)
joev
Are you using EI? If so, there is a route through EIM to OBJ.
I haven't had much luck but Pauls has, check this thread:
http://forums.cgsociety.org/sho...86&t=482195&page=1&pp=15
bmeissner
#3 Posted : Tuesday, April 17, 2007 10:51:36 AM(UTC)
bmeissner
Martin,
i just did a test using VRML (1), which worked perfectly, including colors. You can't set the mesh resolution during export, but the default settings seem to work fine. BTW, I tried this with C4D v6, which is very 'picky' with meshes. If it works here, it should work even better in newer versions.
Bernd
Martin K
#4 Posted : Tuesday, April 17, 2007 11:41:35 AM(UTC)
Martin K
Hi Joev, unfortunately I have an early version of EIM which does not support obj.
Martin K
Martin K
#5 Posted : Tuesday, April 17, 2007 11:42:25 AM(UTC)
Martin K
bmeissner wrote:
Martin,
Bernd
I'll try that. Thanks
Martin K
Martin K
#6 Posted : Tuesday, April 17, 2007 3:25:20 PM(UTC)
Martin K
bmeissner wrote:
Martin,
Bernd
The VRML worked very well. thanks!
Martin K
