Toggling through open windows shortcut (#5187)
Is there a way to create a shortcut to toggle between open windows? Going to the Windows menu on top is so slow. Perhaps there is a quick way of doing it already available...?
I'm on a mac. I used hot corners in mission control.
Ctrl and tab in Windows. It also zooms extents, you don't revert to the zoom scale you left.
Great suggestions both - thanks!
Thanks: 103 times Was thanked: 110 time(s) in 72 post(s)
Personally, I really dislike the "zoom to extents" result of doing alt-tab. Creating a new window and then alt-tabbing back to the prior window has the same result. It is very disruptive. Alt-tab with zoom-to-extents also causes selection of a layer (highlighted, not one that is checked as active) to go back to the Construction layer. // rant off
