nanoplane
#1 Posted : Saturday, September 29, 2012 11:08:16 AM(UTC)
nanoplane
I'm on MacOS 10.8.2 and photo rendering just doesn't seem to work. I just get a Black shape on the resulting screen, no detail, no reflections, no color, just black...
What Might I be doing wrong??
#2 Posted : Saturday, September 29, 2012 2:20:02 PM(UTC)
Check your monitor's on first - sorry !
Hmm
Not sure - can you go back to the simplest scenario - restart the app, draw a sphere and render - will it give you a result then ?
nanoplane
#3 Posted : Saturday, September 29, 2012 4:21:46 PM(UTC)
nanoplane
:-).. monitor is on..
Going back to basics.. if all I do is create a sphere, I get somewhat reasonable but unexpected results...
"User Specified" render's the sphere in the color I selected and for the most part, some of the attributes make sense.
Metal, Plastic, Glass and Mirror give unexpected results..
Metal comes out as a gold color, seems to be reflecting some image that I haven't defined anywhere I can tell. (checked the render settings, foreground and background set as none)
Glass renders as a black sphere with no detail
Plastic renders as an almost black sphere with some evidence of reflection of that same image as metal.
Mirror gives me a render similar to Metal.
Sketch is just weird. Sphere is solid color, no highlights .
And....
If I add another body to the drawing (say a cylindrical pedestal for the Sphere), That second body comes out black in all views except metal and mirror.
#4 Posted : Saturday, September 29, 2012 5:39:51 PM(UTC)
I suspect things are different in ViaCAD - I'm using Shark and seem to get better results than you.
These used to be called 'Rapid-render Presets' - a name that explained well what they did
Now they have no name except for "Glass" - it makes it look like this is all you can do with this renderer - which I assure you is not the case.
If you want better results, don't use the presets - as they are just quick and dirty and they give you what they give you. You need to fish around for a texture from the texture library - then adjust that to your needs, add and environment - add lights etc ... just as you would in a studio.
The rendering engine is Lightworks (http://www.lightworkdesign.com/index.html) - which is good - though there do seem to be better renderers around these days.
The interface however is all Punch! - and was ok 10 years ago - but not now.
nanoplane
#5 Posted : Saturday, September 29, 2012 6:05:05 PM(UTC)
nanoplane
It does seem to be really flaky... even rendering only a sphere, when you assign a textured surface of one color, photo rendering changes the color.
Just doesn't seem to work at all for anything complex... except in the video, of course :-).. but that's on a PC, not a Mac.
LLoydSp
#6 Posted : Tuesday, October 2, 2012 6:53:19 AM(UTC)
LLoydSp
Viacad Pro V7
I have several metals in my model, with photo-render materials from the library applied to individual parts.
However, when I render with "metal", everything turns out shiny brassy gold.
When I render "plastic", everything comes out with the "inspector" colors for the drawing objects, and not the materials I've applied from the render library.
There must be a way to make individual metal parts look as if they're different materials, but still keep the 'metal' textures and colors.
I know one can use the "user defined" rendering button to get the colors assigned from the Rendering Library, but so far, I have not found colors or finishes that match the 'look' of the pre-defined settings in the rendering pallet.
A second problem, which has just cropped up after a year of using -- when I photo-render now, it hangs up after pass 1/2, and will not "finish" unless I press ESC. It finishes if rendering to file, but not if rendering to the screen (in any mode, fenced or not).
Any clues here?
Help??
LLoyd
