macnavi
#1 Posted : Monday, February 10, 2014 4:35:25 PM(UTC)
macnavi
Netherlands
Freshly opened ViaCad 2D/3D 9 and spending a few minutes with one file, opening an empty, new one. Now in v8 I could switch with command-` between windows, but that didn't work. So looking in the Window menu, I only saw my new, Untitled project. Though as you can see in the screenshot, the other one is open as well behind it. Something to fix?
Note as well that the layers don't have visibility icons in front of it. It just doesn't show it, even though all layers are visible (they are all empty). When you click on the visibility icon (or where it normally is), the layer disappears. Click again, the layer (when something on it) appears again, but not the icon. Something else to fix as well?
macnavi attached the following image(s):
Screen Shot 2014-02-10 at 22.29.13.jpg (44kb) downloaded 5 time(s).
rockyroad_us
#2 Posted : Tuesday, February 11, 2014 12:04:58 PM(UTC)
rockyroad_us
Yes. I confirm that too.
#3 Posted : Tuesday, February 11, 2014 12:50:20 PM(UTC)
Confirmed on Shark FX 1108
Luis G.
MacOSX Sonoma 14.7.1
#4 Posted : Tuesday, February 11, 2014 11:19:35 PM(UTC)
I think that I experienced that in Shark LT v8, although I'm running SLT in win7, unpatched, inside of VBox 4.1.18 r78361.
I think I found that I had to use the menu to get at the other open drawing/s. I only recall experiencing it within the pas 11 months, and maybe 2 or 3 times. Not sure what ended it. Either stripping and resaving a file (which, IIRC, was over 80mb saved and around 800mb worth of RAM opened with lots of layers active/unhidden) I suspected was corrupted but still editable, or maybe I upgraded VBox after the issue.
Hope this is useful rather than unhelpful.
