Hello Tim,
The IGES file has been created with ViaCadPro V8, so I thought I
It can work in V9.
I often get IGES files from a variety of CAD systems
come. SolidWorks, Solid Edge ZW3D, just to name a few can all
to bear in ebiten ViaCadPro V8 without further on.
I realize that I should use SAT files to the exchange, but
Unfortunately, it often happens that I get only IGES data.
If you need other IGES data from SolidWorks or so then the
no problem. I have enough here.
Edit:
I have just tried an IGES created with ViaCadPro V9 itself
invited back and continue editing.
Here also the same. It may not even own the IGES again
be used.
I load the IGES from the V9 in the V8 everything goes without problems.
The only information as maybe this will help you further yes.
greeting
Dieter
 V8_OUTPUT_IGES_FILE.zip
(32kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
