Suggestions
Hanging when pressing ESC when cancelling Bezier line (#4763)
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
The Escape key is a dangerous thing to use. When creating a bezier line and pressing the ESC key, the message appears if you want to cancel the action. Then it's too late, it already hangs and Viacad needs to be force quitted. The only way to cancel the action is right click to confirm the line and undo. The hanging not always happens, but it does happen so much that it is easily repeatable. Is that only me or is it a bug and have other users the same experience?
Thanks: 2 times Was thanked: 29 time(s) in 21 post(s)
I cannot repeat! Work fine here, I have no message for cancelling the operation.
>>The Escape key is a dangerous thing to use. With v9 (build 1075) I went to a more conservative approach with the ESC key. Tim
Thanks for the replies. Here's a small video where you can see what happens. Try to replicate this!
http://youtu.be/0LDUqc7aezA Tim, I've got build 1016, can I get the build you mentioned already?
Suggestions
