DJ-Bino
#1 Posted : Monday, January 20, 2014 5:13:49 AM(UTC)
DJ-Bino
Hello,
I have the following problem. Imortiere IGS files can not be further processed in ViaCAD Pro V9 Build 1104.
All the Bolean try to use functions fail.
In ViaCAD Pro V8 I have no trouble. There I can
So on edit imported IGS files as I want and all
Use functions.
Sorry for my bad English (I hope it gets better with time)
regards
Dieter
DJ-Bino attached the following image(s):
Bug V9 Build 1104.jpg (68kb) downloaded 6 time(s).
#2 Posted : Monday, January 20, 2014 10:26:55 AM(UTC)
Hello Dieter
Can you private email me or post the IGES file?
Thank you
DJ-Bino
#3 Posted : Monday, January 20, 2014 10:44:02 AM(UTC)
DJ-Bino
Hello Tim,
The IGES file has been created with ViaCadPro V8, so I thought I
It can work in V9.
I often get IGES files from a variety of CAD systems
come. SolidWorks, Solid Edge ZW3D, just to name a few can all
to bear in ebiten ViaCadPro V8 without further on.
I realize that I should use SAT files to the exchange, but
Unfortunately, it often happens that I get only IGES data.
If you need other IGES data from SolidWorks or so then the
no problem. I have enough here.
Edit:
I have just tried an IGES created with ViaCadPro V9 itself
invited back and continue editing.
Here also the same. It may not even own the IGES again
be used.
I load the IGES from the V9 in the V8 everything goes without problems.
The only information as maybe this will help you further yes.
greeting
Dieter
V8_OUTPUT_IGES_FILE.zip (32kb) downloaded 7 time(s).
#4 Posted : Monday, January 20, 2014 12:43:22 PM(UTC)
Hello Dieter,
This is now fixed in the 1108 code stream builds. Thanks for sending the file. Until you get the update, you can use the Stitch tool to convert surfaces from IGES into a solid.
DJ-Bino
#5 Posted : Monday, January 20, 2014 1:18:44 PM(UTC)
DJ-Bino
Hi Tim,
Thanks for the quick reply!
I will as long as the Stitch tool use is not a problem
greeting
Dieter
